Wireless Guest and mac authentication
gnijs
Level 4
Level 4
Hi all,
I want to setup a wifi guest network with mac based authentication.
I already have the guest anchor controller and the remote wlc controller (and the mobility tunnel) up and running.
However, i am uncertain where i have to program the mac addresses: on the remote wlc or on the guest controller ? (for local database mac)
It seems my authentication only works if i program the mac address of the 'remote' wlc (the wlc holding the AP).
   This is a pitty, as i was hoping to centralise all "appoved" mac addresses on the guest controller and not on each individual wlc seperatly.
Also, suppose i want a radius server to validate the mac address. Which controller is going to sent the radius request ? the wlc controller
managing the AP or the guest anchor controller ?
Does the remote wlc also need to be configured with "Layer2 security: none"+"mac authentication" (the same as the anchor controller) or can i put "Layer2:none" and put the anchor controller on "Layer2: none"+mac authentication ?
regards,
Geert
Nicolas Darchis
Hi Geert,
The rule is straightforward : layer 2 is handled by foreign WLC (one holding the AP) and layer 3 handled by the anchor (the guest).
This means the anchor WLC handles the dhcp/ip address, it handles the web authentication etc ...
But only the foreign WLC knows which AP the client is associated to, it's the only one to have layer 2 information so that's the one doing layer 2 authentication (wpa psk or mac filtering).
The way to "centralize" for you would be to have the mac addresses on a radius server or to push the mac addresses on the controllers via WCS.
Hope this clarifies,
Nicolas
Don't forget to rate answers that you find useful
Nicolas Darchis
Hi Geert,
Nicolas
Thanks Nicolas. This clarifies a lot.
regards,
Geert
