Wireless guest with Anchor controller question
kerek
Level 8
Level 8
I'm almost clear how to configure the Wireless guest using anchor controller however I have a question.
I have a centralized WLC and APs spread across locations in H-REAP mode.
I have few upcoming sites requiring local WLC due to number of APs on site. I also have a guest WLAN with webauth.
I planning to use the same guest WLAN (since I have centralized Internet breakout) through the central WLC using anchoring feature.
So far so good (I hope).
The question is whether I can use the same guest WLAN on the centralized (anchor) WLC by the foreign WLCs as well the APs already associtated to this controller? Since I need to anchor the WLAN on the central controller itself I don't know if it creates any problem for the APs associated to this controller directly.
Or
Is it better to setup a new WLAN for the guest WLANs being used by the foreign controllers?
Krisztian
Nicolas Darchis
It's not a problem.
The remote WLCs will use the central WLC as anchor for the guest WLAN.
And on the central WLC, you have to configure the guest WLAN to anchor with itself (i.e. the central WLC).
I don't see a problem with that.
Nicolas
Nicolas Darchis
It's not a problem.
Nicolas
Thank you Nicolas.
I will try it out anyway soon so will see if there is any issue.
