Wireless Heatmap Location
BrendonFranca
Hello, Guys.
I have a question about the Location Heatmap. We have a timeline of the last 24 hours of the heatmap. I would like to know if there is any way to descrease this interval from 24 hour, for exemple, 1 hour. Is it possible ?
BlakeRichardson
Meraki Community All-Star
@BrendonFranca Not that I can see in the documentation. You can drag the slider along but it only adjusts by 60 min increments, and I am guessing that its set this way so that the dashboard isn't bogged down.
I would say Meraki want to keep a fine balance between the devices uploading a useful amount of traffic information vs to much.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
BlakeRichardson
Philip D'Ath
Devices often only emit a "bleep" every 10 minutes when they are asleep. If you reduced the granularity down to an hour there wouldn't be enough data points to draw any usefull information.
