Wireless Help
Amitdivekar
Community Member
Hello All,
I need some inputs so as to is this can be done,
I have a Lynksys wireless setup in my Office,
1. I want to know which user is connected to the wireless
2.What is the signal strength that he is getting, or how far is he from the Ap.
3.A detailed report of the downloads the user is doing.
4.Sites the user has accessed.
Is there any third party tool that can help me in generate such a report, or please suggest me a way through which i can generate such a report.
Amit
wong34539
Level 11
Level 11
Linksys EasyLink Advisor, aka LELA is a little application to help you set up and maintain your new or existing wireless and wired network.
LELA can be downloaded at the Linksys EasyLink Advisor Download url:
http://update.linksys.com/lela/install/lela.exe
