Wireless HOTSPOT: some clients unable to connect.
We have a wireless hotspot (using ISE) some users are unable to connect to the SSID.
When running a debug client for the device that is unable to connect is can see the following debug messages:
spamApTask4: Dec 18 14:59:48.824: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:90:a5:0d:73:15 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask1: Dec 18 14:59:49.858: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:20:56:8d:f0:45 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask4: Dec 18 14:59:49.936: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:90:a5:0d:73:15 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask1: Dec 18 15:00:01.021: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:20:56:8d:f0:45 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask4: Dec 18 15:00:01.121: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:90:a5:0d:73:15 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask4: Dec 18 15:00:02.257: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:90:a5:0d:73:11 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask1: Dec 18 15:00:05.966: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:20:56:8d:f0:41 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask4: Dec 18 15:00:06.054: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:90:a5:0d:73:11 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask4: Dec 18 15:00:16.769: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:90:a5:0d:73:11 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
*spamApTask4: Dec 18 15:00:17.629: e4:fd:a1:b0:b2:e1 Association Failed on REAP AP BSSID 38:90:a5:0d:73:11 (slot 0), status 43 0 Non-WPA2 in Adaptive 802.11r
There is o authentication required for the hostspot.  Can this be related to Fast Transation? the setting on the WLAN is set to Adaptive.?
Scott Fella
Disable FT on the wlan. Seems like devices are not compatible with FT enabled or in adaptive.
-Scott
Simples e direto, solucionei o problema de um cliente com esse post.
Good Job
