Wireless implementation Query
Prasan Venky
Level 7
Level 7
Dear All,
Consider I have one WLC and few AP's to be installed on my premises. My requirement is to create two SSID's as Secure & Guest. I want to restrict guest vlan to only access internet while Secure vlan able to access whole corp. resources. How do i achieve that...?
Please provide your suggestions.
Thanks in advance...
KVS
2 Accepted Solutions
Amjad Abdullah
KVS:
You can use ACLs on the neighbor switch to restrict the traffic of the guest VLAN.
If you have a firewall you can use policies on the firewall as well.
Amjad
useful replies is more useful than saying "Thank you"
Rating useful replies is more useful than saying "Thank you"
Leo Laohoo
Your Guest VLAN's default gateway is your internet default gateway.  You create an ACL on the router saying that the Guest subnet can talk to the same subnet and "deny ip any any" is explicit.
Amjad Abdullah
KVS:
Amjad
Leo Laohoo
Abhishek Abhishek
Hello Prasan,
As per your query i can suggest you the following solution-
Yes you can use ACLs on the neighbor switch and it will restrict traffic on the gueat VLAN.And you can easily create two SSID's as Secure and Guest.
Hope this will help you.
