wireless interface on a 877W
davieshuw
Level 7
Level 7
Hi. I've got experience of configuring 1131's and 1242 access points, but im having a little bit of trouble getting the wireless to route properly on my 877W.
Basically I can connect to my wireless, but I never get an IP address, my DHCP simply times out.
Now the setup I have is...
VLAN1 192.168.17.1
Dialer0 public IP
I'm sure I need to bridge the wireless traffic into VLAN1 if possible, but im not sure how to do that?
Any ideas?
THanks!
amritpatek
Level 11
Level 11
Follow the configuration guide to configure the Cisco877 router which may help you in you configuration :
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
Scott Fella
Try this template.... help me setup mine at home:
http://articles.techrepublic.com.com/5100-10878_11-6112367.html
-Scott
