Wireless ip scheme
larnelhight
Level 2
Level 2
Quick question:  Any negative impact on placing the user wireless DHCP scheme onto the same vlan used for WAP's ip scheme?  Or is it better to place the users onto a different vlan?
Larnel
Nicolas Darchis
I haven't seen any problems with that. You won't have broadcasts from the clients hitting the wired network anyway so that's one thing less to worry about
