Wireless Lan Controller 5504
alfandyperdana
Visitor
How to get device cert for web auth?
8 Replies 8
can you explain how to get device cert, i confused to undersranding the article
There are many good blogs out there in regard to this. Just search “Cisco wlc guest certificate”. You basically need to purchase a certificate and have access to create a DNS entry for the Guest certificate you create. Here are some links:
https://www.rogerperkin.co.uk/wireless/how-to-install-ssl-certificate-on-cisco-wlc-for-guest-access/
videos:
https://www.youtube.com/watch?v=OJNzqN0ygBo
https://www.youtube.com/watch?v=gDMZmf0nWPA
-Scott
i success upload certificate for web admin but always fail when upload for web auth
did you generate CSR from WLC or via Openssl ?
if you are using Open ssl then use OpenSSL Version 0.9.8
Dont forget to rate helpful  posts
i am generated csr from open ssl and send to comodo free ssl, i have get *domainname*.crt and *domainname*.ca-bundle. what should i do?
(Cisco Controller) >*TransferTask: Oct 08 11:57:01.370: Memory overcommit policy changed from 0 to 1
*TransferTask: Oct 08 11:57:01.370: RESULT_STRING: TFTP Webauth cert transfer st arting.
*TransferTask: Oct 08 11:57:01.370: RESULT_CODE:1
*TransferTask: Oct 08 11:57:05.374: Locking tftp semaphore, pHost=172.20.254.52 pFilename=./final-certdigi.pem
*TransferTask: Oct 08 11:57:05.458: Semaphore locked, now unlocking, pHost=172.20.254.52 pFilename=./final-certdigi.pem
*TransferTask: Oct 08 11:57:05.458: Semaphore successfully unlocked, pHost=172.20.254.52 pFilename=./final-certdigi.pem
*TransferTask: Oct 08 11:57:05.463: TFTP: Binding to remote=172.20.254.52
*TransferTask: Oct 08 11:57:05.769: TFP End: 7915 bytes transferred (0 retransmitted packets)
*TransferTask: Oct 08 11:57:05.770: tftp rc=0, pHost=172.20.254.52 pFilename=./final-certdigi.pem
pLocalFilename=cert.p12
*TransferTask: Oct 08 11:57:05.770: RESULT_STRING: TFTP receive complete... Installing Certificate.
*TransferTask: Oct 08 11:57:05.770: RESULT_CODE:13
*TransferTask: Oct 08 11:57:09.774: Adding cert (7851 bytes) with certificate key password.
*TransferTask: Oct 08 11:57:09.810: RESULT_STRING: Error installing certificate.
*TransferTask: Oct 08 11:57:09.810: RESULT_CODE:12
that is the error i got
upgrade software to 8.0.152.0 and try again.
