Wireless LAN Controller 5508 - Boot Problem
fbarquero.fusionet
Community Member
Hi Team,
I have a question. I just turned on 2 Wirelless LAN Controllers 5508 and I am getting this message on both of them:
Loading primary image (Image not found)
** Unable to read "linux.pri.img" from ide 0:2 **
Loading backup image (Image not found)
** Unable to read "linux.bak.img" from ide 0:2 **
And it is taking me to the BootMenu. I selected option 4 to Clear Configuration and the controller seems to restart the system but I still get the same error.
I checked the LEDs status and Sys is Amber and Alarm is OFF which according to the documentation is a System Crash. Has anyone suffered this issue?,
Federico Barquer Barquero
Stephen Rodriguez
Sounds like both of them have HD that are borked.
you'll need to RMA them
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
