Wireless LAN Controller 5508 - Web Auth, change unsuccessful logon attempts
msingh2007
While using the Web Auth, a user is allowed to try logging in a maximum of three times.  Once they reach the third attempt, the wireless connection stops and disconnects.  Is there a way to change the unsuccessful logon attempts from three to another amount?  I am trying to find it but can't find it anywhere.
Scott Fella
You can't change that value of 3, you can either disable client exclusion or reduce the time before the clients gets removed from the exclusion list.  This would be loacted under the WLAN > SSID > Advanced tab.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
