Wireless LAN Controller Throughput
mukesh.patil
Community Member
Experts,
Assume  the below scnario
Wireless Clent = 6000 all AC supported
AP = AC supported 3700
WLC = 55xx or 57xx ??
5508 = 8 Gbps throghput
5760 = 60 gbps throughput
Which controller should i plan for this scnario and why?
-Mukesh
ammahend
do you have 6000 clients or 6000 wireless endpoints, if you have 6000 clients, then easily you have 12000 endpoints and 5508 supports only 7000 end points , if you have 6000 end points including wireless guest then my next question is do you want the traffic to be centrally switches or locally switched ??
-hope this helps-
What is recommended configuration of larger campus with 6000+ 802.11ac supported client? Why?
ammahend
since you dint mention anything about 3850s with IP base I am assuming you are not at all looking at converged access.
-hope this helps-
