Wireless LAN Controller
ladislao2006
Level 2
Level 2
Hi!
May I do an Upgrade of my WLC-4402 in order to support 802.11n??
Actually is only supported by 802.11b,a and g.
Thank You!!
Scott Fella
You need 1252 access points and a minimum of 4.2 code on the WLC. 1131AG, 1242AG and any other access points besides the 1252's will not support 802.11N.
-Scott
