Wireless LAN Controller
nickh2022
Hello Everybody,
I have a WLC 4402 plugged into a Catalyst 4507R. My problem is I am unable to ping the WLC from a different VLAN. While reading the document about best practices, it mentions that the fiber port should be configured using dot1q encapsulation but when I try to configure that, I do not get encapsulation as an option. The wierd thing is, other ethernet ports on the switch do have encapsulation configured. Please advise!
36 Replies 36
Ok, enough speculation. Please post the switchport config and controller config. At least the networking part of the controller config.
I am only testing..So I can post my config. Here it is.
Cisco Controller) >show running-config
802.11a cac voice tspec-inactivity-timeout ignore
802.11a cac voice stream-size 84000 max-streams 2
802.11b cac voice tspec-inactivity-timeout ignore
802.11b cac voice stream-size 84000 max-streams 2
aaa auth mgmt local radius
Location Summary
Algorithm used: Average
Client
RSSI expiry timeout: 5 sec
Half life: 0 sec
Notify Threshold: 0 db
Calibrating Client
Half life: 0 sec
Rogue AP
RSSI expiry timeout: 5 sec--More-- or (q)uit
Half life: 0 sec
RFID Tag
Half life: 0 sec
location rssi-half-life tags 0
location rssi-half-life client 0
location rssi-half-life rogue-aps 0
location expiry tags 5
location expiry client 5
location expiry calibrating-client 5
location expiry rogue-aps 5
ap syslog host global 255.255.255.255
--More-- or (q)uit
auth-list add lbs-ssc 00:1b:24:df:f2:5c cbd944156e8248baf99fac0356770099d9dadf5
cdp advertise-v2 enable
dhcp create-scope Test
dhcp address-pool Test 10.1.220.50 10.1.220.60
dhcp default-router Test 10.1.220.237
dhcp enable Test
dhcp dns-servers Test 66.109.229.5 66.109.229.6
dhcp network Test 10.1.220.0 255.255.255.0
local-auth method fast server-key *****
interface create data 220
interface address ap-manager 10.1.120.251 255.255.255.0 10.1.120.237
interface address dynamic-interface data 10.1.220.237 255.255.255.0 10.1.220.237
interface address management 10.1.120.250 255.255.255.0 10.1.120.237
--More-- or (q)uit
interface address service-port 10.1.5.212 255.255.255.0
interface address virtual 1.1.1.1
interface dhcp ap-manager primary 10.1.5.45
interface dhcp dynamic-interface data primary 10.1.5.45
interface dhcp management primary 10.1.5.45
interface dhcp service-port disable
interface vlan data 220
interface port ap-manager 29
interface port data 29
interface port management 29
lag enable
load-balancing window 5
--More-- or (q)uit
memory monitor error disable
memory monitor leak thresholds 10000 30000
mesh security eap
mgmtuser add administrator **** read-write
mobility group domain MVE-WLAN
network telnet enable
network mgmt-via-wireless enable
network otap-mode disable
network rf-network-name MVE-WLAN
sessions timeout 160
snmp version v2c enable
--More-- or (q)uit
snmp version v3 enable
spanningtree port mode off 1
spanningtree port mode off 2
sysname MVE-WLC
time ntp interval 3600
time ntp server 1 192.168.1.253
wlan create 1 MVE MVE
wlan broadcast-ssid disable 1
wlan radio 1 802.11g
wlan session-timeout 1 1800
wlan wmm allow 1
wlan security static-wep-key encryption 1 104
--More-- or (q)uit
wlan security wpa akm 802.1x disable 1
wlan security wpa akm psk enable 1
wlan security wpa wpa1 enable 1
wlan security wpa wpa1 ciphers tkip enable 1
wlan dhcp_server 1 0.0.0.0 required required
(Cisco Controller) >
My switchport config is
interface GigabitEthernet6/15
description ***Wirless Controller***
switchport trunk native vlan 20
switchport trunk allowed vlan 2,20
switchport mode trunk
Hmmm...you should have a "switchport trunk encapsulation dot1q" on your switch config. Your switch should support dot1q trunking. If that doesn't work, try upgrading the IOS on the switch.
That's kind of my issue. For whatever reason when I go to setup Encapulation on that port, it is not an option. However, other ethernet ports and other fiber ports have it enabled. So I know that my IOS supports it. I have tried other fiber ports, but encapsulation is not an option on those other ports either.
Try another switch that you know supports dot1q trunking.
The IOS does support it. Plus other ports are configured with it.
Do a "show run-config" and compare it to below:
witch Configuration
802.3x Flow Control Mode......................... Disable
Current LWAPP Transport Mode..................... Layer 3
LWAPP Transport Mode after next switch reboot.... Layer 3
FIPS prerequisite features....................... Disabled
Secret obfuscation............................... Enabled
This is what I have
Switch Configuration
802.3x Flow Control Mode........ Disable
Current LWAPP Transport Mode..... Layer 3
FIPS prerequisite features.... Disabled
Secret obfuscation............. Enabled
Well, I'm all out of ideas other than taking the controller out of lag mode and configuring the switchport as a host, just to see if the controller's hardware, including gbics and cable is ok. The controller should respond at layer3 if there are no hardware issues. We have about 80 controllers in offices across the country and I have yet to see a problem at layer3 with these.
Well..I really appreciate you trying..I currently do have LAG enabled but am not taking advanatge of it...I only have 1 gbic installed. So, I do not have port-channeling enabled on the switch either. Could that be a problem?
Well, I think you just thought through your entire problem. You need to setup a port channel for lag mode. It will take you all of about 10 seconds! heheheh
Even if Im not technically using it because Im only using 1 distribution port on the 4402?
I disabled LAG, still can not ping the WLC outside its own VLAN
Start from scratch, erase config on WLC and rebuild without using LAG.
