Wireless Lan Controller
N.UddinSheikh
Please can some explain me this , i have cisco wireless lan controller TH-C2504 i have 3 different SSID configured on it i would like to block skype any kind of voice streaming on one of the SSID.
Sandeep Choudhary
use AVC to block it.
  • create an AVC Profile
  • edit the AVC Profile
  • Add New Rule
  • select the group and application and mark it is drop/block
  • then go to wlan config, under QoS tab, enable AVC and apply the profile.
here is the simple guide...(just for basic info):https://mrncciew.com/2013/03/28/configuring-avc-on-wlc-7-4/
Dont forget to rate helpful posts
Sandeep Choudhary
  • Add New Rule
Hi Sandeep
thank u so much for the answer matey .
