wireless LAN Controller
MD KAFINUZZAMAN
Level 3
Level 3
Is there any issues in wlc image, v17.05.01?
Mark Elsen
 - There where always be issues in the modern complex world if and or (...etc)  , for instance you look at later releases , examine Release Notes and look at Resolved Caveats (e.g.) . In practice you take your current environment , and look at problems if any. Also advisable is to use a recommended release : https://software.cisco.com/download/home/286321396/type/282046477/release/Amsterdam-17.3.5a
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Is there a specific new feature that you need? If not I would stick to suggested release or the newest from that release (17.3.x). If there is a feature that you need from 17.5, I would directly go to 17.6 which will be the next long-term release.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Leo Laohoo
Do not play with "single-release" versions like 17.1.X, 17.2.X, 17.4.X, 17.5.X, 17.7.X or 17.8.X into production.
Long-term releases are 17.3.X, 17.6.X, 17.9.X and 17.12.X.
