Wireless LAN controller
I'm looking to deploy a WLAN network using AP's, Radius and Certificates.
Do I need a WLAN controller? If so, what does it perform.
SD
theo_chimbga
Community Member
There are 2 types of AP, i.e. autonomous and lightweight. You only need a WLAN controller if you plan to use lightweight APs. As the name suggests, the controller manages all APs associated with it in a configuration known as split MAC where the AP handles real-time events while the controller takes care of security and other "back-end" processes. In contrast autonomous APs have full IOS and each handles all processing. This is just a teaser but there's plenty of docs on Cisco! Theo
Thanks Theo.
Pleasure is all mine...
