Wireless LAN Solution Engine: discover fails !!!
f49713
Community Member
I tried to discover 3550-Switche with our Cisco WLSE V2.5. Two 3550 devices working fine (V12.2.(8)EA1)+(V12.2.(9)EA1).
Other 3550 devices with V12.2.(13)EA1 didn't respond. I don't know why. (same config)
-I checked the SNMP-connection with the WLSE query
tool. Works fine!
-ACL ist activ but the WSLE IP-Address ist permited.
Works fine with two devices.
Thank you in advance
Arno Hagedorn
5 Replies 5
amitubale
Level 4
Level 4
IS CDP enabled on the devices ?
f49713
Community Member
Thank you for reply.
Yes,it is. cdp works fine.
Switch01#sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
Swich02 Gig 0/1 145 S I WS-C4506 Gig 2/1
A19.route.Fas 0/21 127 AIR-AP350 fec0
A28.route.Fas 0/24 167 AIR-AP350 fec0
A26.route.Fas 0/22 155 AIR-AP350 fec0
A27.route.Fas 0/23 159 AIR-AP350 fec0
Arno
From your WLSE GUI, under Administration->Appliance->Connectivity Tools->Network Tools, run the SNMP Reachable Test for the device in question. If it fails with a timeout error etc, then we know that SNMP between the WLSE and this device is not working.
f49713
Community Member
I checked the switch with the snmp query tool.(IP and hostname.domain-name) -works fine-.
All switches I'am interrested can be reached with the tool.cdp an snmp is enabled on all switches.
I discovered two switches:
1.cdp only discovered directly connected access points but switch 172.22.4.50. is missing.
Seed value entered: 172.22.4.50
Hop count defined: 1
CDP Discovery started at 2004-01-20 18:53:07.763 (UTC)
Device being updated :172.22.11.119 (a19.heraeus.com)
Device being updated :172.22.11.128 (a28.heraeus.com)
Device being updated :172.22.11.126 (a26.heraeus.com)
Device being updated :172.22.11.127 (a27.heraeus.com)
Number of devices (re)discovered: 4
Inventory collection does not run for updated devices, run on demand or wait for the next polling cycle.
CDP Discovery completed at 2004-01-20 18:53:08.462 (UTC)
2. cdp works fine!!! AP's and switch is discoverd.
Seed value entered: 172.22.4.42
Device being updated :172.22.11.136 (a36.heraeus.com)
Device being updated :172.22.4.42 switch.heraeus.com)
Number of devices (re)discovered: 2
CDP Discovery completed.
Try increasing the CDP Distance/Hop Count in WLSE from 1 to 3 or 4 and then run the discovery again.
