Wireless LAN
fb_webuser
Level 11
Level 11
I have installed a 5508 WLC in HA mode. The problem persists with the LAP in the area. We had an external vendor doing site survey and accordingly installed LAP.but now the issue is some users don't get connectivity beyond 11m from LAP and some users switch within LAP even if they are static
Can sumne help me to point out root cause?
Posted by WebUser Shalini Menon from Cisco Support Community App
7 Replies 7
Ravi Singh
Level 11
Level 11
Please specify the physical architecture of Site. So that we can come to know what kind of environment you are running with. Also check wireless inference.
fb_webuser
Level 11
Level 11
issue already resolved..but thanks
Can you post the resolution?
-Scott
Abhishek Abhishek
The issue might be due to interference or weak signal strength. Anyways, please do post the resolution.
fb_webuser
Level 11
Level 11
The LAP proved insufficient in the area considering the strength of users..Also some of the users failed 802.1x
authentication
Thanks for sharing. It helps posting the solution especially if someone searches and hits your thread.
-Scott
fb_webuser
Level 11
Level 11
oh there was nothing that i changed.. so i tght :(..sowie
