Wireless Lan
bantiagarwal
Community Member
We want to Connect two different buildings of 22 KM distance through wireless lan
how and can some one help me out
Hi Banti,
Sure, You can use the wireless bridges from Cisco. You'll have to se 2 bridges, one as a root bridge & another one as a non-root bridge. You'll have to deploy external antennae keeping distance, interference, line of sight, gain of the antenna under consideration. Preferably get a site survey done from a professional site surveyor to get the exact specs. for the antennae. I can also give u the specs, but it'd be generic & not particular to the ambience around the wireless lan setup.
Your connection might look like this:
Backbone Connection
Switch
Wireless Root Bridge
Wireless non-root bride
Switch
Wired clients.
Lemme know if you need any more infrmation.
Thanks & Regards,
Karthik N
