Wireless link(bridge) between two ap 1300
Hello, i need to configure wireless link between my 1300 series, how can i use them like a bridge and access point in the same time?
Do i need static ip for BVI interfacess between them for bridge or its need to be DHCP, is there any example? i would be great to know that
thank you
5 Replies 5
Amjad Abdullah
Hello Kamran,
Here is a config example:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
and as an answer to your clients quetsoin, yes it is possible to make clients to connect to your bridge:
''snip''
If you want to configure the wireless bridge for root bridge/non-root bridge mode and you have wireless clients that are associated to the wireless bridge, you need to choose either
Root Bridge with Wireless Clients
or
Non-Root Bridge with Wireless Clients
for the Role in Radio Network parameter. In this way, the wireless bridge functions as a root/non-root bridge and also accepts wireless client associations.
''snip''
Reference: Same above link.
Hope this is useful
Amjad
Rating useful replies is more useful than saying "Thank you"
maldehne
Here is a simple config example
Root        Non-Root
R(config)#dot11 ssid test                             n-R(config)#dot11 ssid test
                #authentication open                    n-R(config)#authentication open
               #infrastructure-ssid                       n-R(config)#infrastructure-ssid
               #exit        #exit
R(config)#int d0                                          n-R(config)#int d0
               # ssid test                                                  #ssid test
                #statio-role root bridge wireless-client          #station-role non-root bridge wireless-client
                #no shut                                                   #no shut
For BVI interfaces you can assign either static or dynamic IP address
But it is highly recommended to have static ip for better management.
Maidehne,
I made it all before, but the problem now is, that on my non-root bridge Dot11Radio 0 interface in reset mode
and only one error was appeared that
DOT11-CANNASSOCIATE:no response
why interface is in reset
Here is a useful link: https://supportforums.cisco.com/docs/DOC-4638
You need to:
- Make sure your root and non-root bridge hear each other.
- Make sure configuration is the same for SSID's name, authenticatoin and encryption.
If you can paste us config in both root bridges that will be good to check config for you.
Greetings,
Amjad
Interface in Reset means that it is searching ( scanning ) for a channel to assume on the radio interface.
On non-root it should hear the SSID being broadcasted from the root on the channel at which the root is operational.
Try the following:
Bring the root next to the non-root and see if it works
make sure that you have clear line of site
Also make sure that the channel configured under the radio interface on the root side is not congested or noisy at the non-root side. You can use the carrier busy test to verify that.
Please Don't forget to rate correct answers
