Wireless link CRC problem
desdinova
Community Member
Hi Guys ;
i have a wireless aironet 340 link at 1Mbps speed. But since that link been activated i am getting too many CRC and duplicate frame errors , to prevent this antenna location been changed on ISP side ( to avoid interference ) but not fixed. And in the logs there are too many "queue full discards" messages. By the way when i cahnge the root state on the bridges , the parent side's snmp traps gives radio interface error (but link is up with errors ).
what shoul i do to bring link clear ?
Best Regards
r-simpson
Level 9
Level 9
It sounds as if you may have too great a distance, to many obstructions, interference and/or an incorrect antenna. Have a wireless site survey done to determine which steps are appropriate next.
dcarter
Community Member
Desdinova-
How far between radios? Do you have a parent ID specified, a frequency specified or are you allowing radio to determine the freq? What kind of antennae?
