Wireless location Appliance
tmailula
Level 2
Level 2
Hi All
I have the AIR-LOC2710-L-K9 with 3.0 code and WCS-STANDARD-K9 4.2 ,but am battling to get them to communicate to each other, do i require some sort of license to get this to work.
Thanks in Advance
jeromehenry_2
Level 7
Level 7
SO it's the WCS standard, but do you have a location license? If you have the base license, location is limited to closest AP, and you won't be able to use the location appliance...
So what you are saying is i need the WCS with the location License to get this to work,
Thanks and Regards
Tau Mailula
Yes, you need WCS with a location license. You can check you license by clicking in WCS Help -> licensing.
Hope it helps.
J
