Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wireless Management ( High)
biplobkhan
Level 4
Level 4
For a Project for Wi-fI have designed 12 1140 AP and 50 Number  1040 AP. Besides We select 5508 Wireless Controller.
Now My question is for AP Management which Product I  am select ?
1. WIreless Controller System
2. WIreless control System Navigator
Please advise.
Biplob
George Stefanick
You would want to lead with WCS or NCS with a license for 75-100 access points. NCS is replacing WCS at somepoint. Navigtor at last check isnt being supported and wouldnt be advisable. That is used to manage large WCS solutions for 1000's of aps.
Make sense?
George Stefanick
Make sense?
HI Geo
Thanks for you rapidly response.
So I can choose either WCS or NCS.  NCS may for prefer Virtualization.
Biplob
NCS is part of a much larger platform Cisco is rolling out. Although, you can still purchase WCS I would lead with NCS as that will be EOL.
