wireless management tools
p.krane
Level 7
Level 7
Are there tools available to manage Ciscos wireless LANs?
mmellet
Level 7
Level 7
Yes, from what I understand the Cisco Aironet access point ships with Web based software tools that can be used to configure and manage the wireless LAN.
jkemery
Level 3
Level 3
You can also use Cisco Works and suplement that with a WLAN sniffer, Network Assoc. or Wildpackets.
jerryshenk
Community Member
Is there any way to get an AIR-PCM350 into promiscuous mode? And a very related question - what chipset does it use? I think the 340 uses the Prisim2 and the 350 is in the same series and I think the same driver works but it doesn't seem like the Prism utilities work with it.
