Wireless Mesh Config
Hi all,
I need to config wireless mesh system.
I have Wireless Control System, Wireless Lan Controller 2100, and access point 1310
Any one can tell me step to config this sys tem.
Thanks all, vote 5* for your help.
7 Replies 7
bbxie
Level 7
Level 7
1310 not support mesh, you should use 1510/1520. for configuration example, you can refer to: http://www.cisco.com/en/US/products/ps6548/prod_configuration_examples_list.html
Hi all,
Thanks bbxie, I voted 5* for your help
I have AIR-BR1310G-A-K9, are you sure this product is not support mesh? Can you show me document to ensure that?
If it not support mesh, can i build wireless network with this access point and wireless lan controller:
- All ap use the same ssid, same security policy
- Roaming between wireless area
Can you tell me step to deploy that?
Any one can tell me step to config wireless network using accesspoint AIR-BR1310G-A-K9 and Wireless Controller 2100:
1310 is not a lightweight AP,, therefore it will not communicate with the lightweight controller 2100.....
I configed 1310 in lightweight AP mode, it joined Controller 2100.
Any one know how to config roaming in my case or it is default?
Roaming between APs on your WLC is enabled by default.
Hi all,
I configed wireless system with controller 2100 and AP 1310
Almost the time system run normally, but sometime one of AP 1310 reboot, but other still run normally.
I don't know why, do you have any suggest about this problem?
How to view log all event on this system?
Thanks all for help
