Wireless Mesh Roaming
Mike Vzz
Level 2
Level 2
hello wireless expert
I have one doubt!!
I'm worked on implementation mode operation mesh
with tecnology wireless centralizaded
my escenario:
area coverage 100 * 200 ft
I have forklifts and its makes moves on all part, need connected it to lan.
will put on forklifts, one ap mode map by connected to lan.
someone knows if the ap mode maps make roaming? when they detect the signal of another rap.
2 Accepted Solutions
Hi @Mike Vzz
 Theoretically yes. When a Map losses connection with a RAP, it must find another RAP and join again. However, the convergence time may not attend to your need. Take a look here:
Table 7 specifically:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1520/troubleshooting/guide/TrbleshtMesh.pdf
-If I helped you somehow, please, rate it as useful.-
Hi @Mike Vzz
