Wireless migration CBW
Jean Welz
Hello Team,
This may be a basic question, but I would kindly like clarification. If I currently have an older WLC 2500 and wish to migrate to CBW for a small business environment, where the existing WLC has three interfaces configured under the controller tab for specific SSIDs, would it be appropriate to migrate to CBW and simply tag the VLANs, given that CBW does not allow interface configuration? Similarly, in the case of migrating to a 9115AXI-WLC, would it also be sufficient to use the standard profiles and VLAN tagging without configuring actual interfaces?
5 Replies 5
Mark Elsen
    - @Jean Welz    I would advice  to migrate to the 9800 controller platform(s) instead ; concerning the need for instance
                             to use different WLANS/VLANS
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi Mark
I would choose that option, but when I reviewed the settings, it seemed straightforward. Traffic can be locally switched, and the WLC can simply map the VLAN on the CBW or even on the 9115-AXI, at least as I understand it. I don’t think there’s any need to configure interfaces, even though they currently exist on the old WLC.
  - @Jean Welz                   How  many access points do you have ?
   M.
Hi @Mark Elsen , So sorry for my late reply. Around 17 APs
  - @Jean Welz     With that install base and or number of  access points in  use , you should always use a 9800 controller.
                             Migrating to  CBW has other disadvantages too; such as access points being less powerful
                             in terms of client capacity and throughput
                             Consider the virtual 9800 controller as an entry point which you can use with up to 50
                             access points without licensing complaints (initially that is)
  M.
