wireless mobility engineer
hamedwasel1
Community Member
*Mar  1 01:42:21.079: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 01:42:24.151: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.142.205, mask 255.255.255.0, hostname AP74a0.2ff3.049c
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.142.200)
Not in Bound state.
*Mar  1 01:43:32.579: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  1 01:43:35.651: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.142.205, mask 255.255.255.0, hostname AP74a0.2ff3.049c
anyone can help me please ,,, this access point is unable to discover our controller ,
thanks in advance ,
hamed wasel
Scott Fella
Not information to help, but here are some things that you should do.
• Verify NTP/Time is correct
• The code running on the controller supports the AP
• Country code on the controller matches the AP
• Place the AP on the same subnet as the controller management
Do you have other AP's joined? Is this a new or existing install?
-Scott
-Scott
Rasika Nayanajith
Hi Hamed,
Have you configured any WLC discovery mechanism? Unless AP & WLC on the same management vlan, AP won't discover WLC automatically. You have to configure it (DHCP option 43, DNS, static or broadcast forwarding). Refer below document
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
If you already configure and still fail to register, see what Scott has suggested, one of that could be an issue
Rasika
*** Pls rate all useful responses ***
Leo Laohoo
DHCP Option 43 is NOT enabled.
Post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time; and
3.  AP:  sh version
