Wireless Mobility
Ranli_Cruz
Community Member
I have 8 Cisco Aironet 1602, i think i can do the wireless mobility. Do i need a wireless controller or it is posible to have the mobility without it? if i need a controller which one is better for 8 APs?
2 Accepted Solutions
Stephen Rodriguez
No, you do not need a WLC to be able to roam gracefully.  What you need is proper cell overlap and configuration.  If you are using a PSK, then the same SSID and PSK on all AP will be all you need.
if you are going to want to do 802.1x, then you'd want to configure WDS, so that one of the AP holds the PMK for the clients so that you can roam with doing a full 16 way handshake every roam.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Leo Laohoo
Straight up, you don't "necessarily" need a WLC.  Like what Steve said, you want to have adequate cell overlap and the correct security/encryption setup.  WDS is also mandatory.
The only time you want to put a WLC is ease of configuration, the ability of the channels and TX power to be "harmonized" through DCA and TPC, respectively, and CleanAir.
Frankly, I'd go for a WLC.  With only 8 APs, you can get the 2504 if you have limited funds.  If you have a healthy budget, you can't go wrong with a 5508.
5 Replies 5
Kyle Nielsen
No the WLC is not needed.
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Leo Laohoo
Ranli_Cruz
Community Member
Nice, i want to have a layer 3 roaming. Could you please help me with the configuration, channels, etcc..?
Ranli,
When you configure the access points make sure they share the same VLAN for each SSID. This way the client will retain the same IP address and pass traffic. Is this what you are asking ?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
