Wireless module problem
pcfreak49
Level 7
Level 7
Hello I have a problem I have a cisco wireless router
because every time I send a file from PC1 to PC2 and differently than
The wireless module will re-start that he's not normal
Who can help because I need it
for my studies
Sincerely
Nicolas Darchis
You asked that question already on this forum and we asked you to provide the console output of the crash .... You still did not provide it.
Nicolas
hoe moet je dat doen want ik heb het dringend nodig voor mijn studies elke kaar dat
je een bestandje stuurt restart de module ?
mvg
If troubleshooting is not in your mind, you can try loading other IOS version on it.
But we cannot tell you why it is reloading if we don't see the reason of the crash.
Nicolas
hier is mijn wireless running-config staat soms iets mis of heb ik verkeerd gedaan kun iemand iets laten weten aub ?
mvg
