Wireless modus
pcfreak49
Level 7
Level 7
I have a problem when I start up my resume in 800 cisco router and I want to go the wireless module, I'm a different mode, how can I fix it?
8 Replies 8
Sandeep Choudhary
Before you configure the wireless settings in the router's setup, you must follow these steps(Check link) to open a session between the router and the access point.
http://www.cisco.com/en/US/docs/routers/access/800/880/software/configuration/guide/880_basic_device_wireless_config.html
Don't forget to rate helpful posts
because if I service-module wlan-ap 0 session to give than I get
Trying 10.10.10.1, 2002 ... Open
Connecting to AP console, enter Ctrl ^ followed by x,
then "disconnect" to return to router prompt
User Access Verification
User: Tim
Password:
ap:
when I start it back I get this message on wireless module
IOS Bootloader - Starting System.
Xmodem file system is available.
Bringing up flash filesystem:
flashfs [0]: 5 files, directories 1
flashfs [0]: 0 orphaned files, directories orphaned 0
flashfs [0]: Total Bytes: 31,481,856
flashfs [0]: Bandwidth used: 38400
flashfs [0] Bytes available: 31,443,456
flashfs [0]: flashfs fsck firing nine seconds.
Reading cookie from flash parameter block ... done.
Base Ethernet MAC address: c8: 4c: 75: 5b: cf: a8
Ethernet Interface initialize.
Ethernet interface initialize OK.
TFTP initialize OK.
button is pressed, wait for button to be released ...
button pressed for 31 seconds
process_config_recovery: Set IP address and config to default 10.0.0.1
Flash: /cpconfig-ap801.cfg: no such file or directory
Configuration restore return 1
The system will go into bootloader for image recovery.
User can download image under bootloader prompt.
ap:
does anyone know how to get the image of the wireless router type 800 series, because can not find it?
Check here:
https://software.cisco.com/download/navigator.html?mdfid=268438003&i=rm
Dont forget to rate helpful posts
Yes the download link for the images but it is intended that I want to delete the images from the 800 series router can not ends in flash
what!!!! Cant understand what exactly you want to do!
You want to delete the old image and insert the new one ??? is it you wanna do ?
yes that's right but find it not in the flash
q
