Wireless multicast over MPLS
Andreew
Frequent Visitor
Frequent Visitor
Hello I have problem with multicast communication over MPLS from WLC to remote client connected to Access Point.
I have WLC 5508 with software  8.0.121.0. and AP AIR-CAP3702E.
Customer buy audio system Audio pro A10. This system is control via wifi application. Control application use multicast. When I configure multicast on WLC, system is working on local network (HQ where is WLC stored), this work fine. Problem is I need control remote location, this location is connected via MPLS to HQ.
Is possible use multicast over MPLS?
Yes, MPLS can transport Multicast. But your provider has to support it.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
 Indeed :
          https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/29220-multicast-mpls-vpn.html#prereq
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
