Wireless N Roaming
pedrodevoto
Community Member
Hi there. I have a WRVS4400N router, and I was wondering if it was possible to implement roaming wireless connection. I had understood that that router didn't allow roaming. In that case, which would be the options to implement a wireless N roaming?
Thanks!
dancampb
Level 11
Level 11
Correct, these routers were designed for small businesses where only one AP would be needed.  If you want to be able to roam you would need either autonomous AP's are lightweight AP's with a controller.
