Wireless Network
pierremonroe
Community Member
I have a T1 line running through a Cisco 2600 router, then to the firewall. Everything runs great. My question is, is it possible to connect a wireless hub to the auxillary port on the router to allow visitors with laptops access to the internet without giving them access to the network?
robert.wright
Level 5
Level 5
AUX ports are not ment for this type of application. AUX are used for remote management.
For your what you want to accomplish, you will want to look into a VLAN solution. 1vlan for employees, 1 for the guests.
