Wireless on 877W with single vlan
localgareth
Hi Guys
I have been struggling for a week now trying to get wireless working on my Cisco 877W. All the other functions are fine, DSL, VPNs, FW, but I cannot get the wireless to work at all.
The configuration is very confusing, and I even resorted to using the SDM, but this messed up other things and still wouldn't work!
I have a vlan1 already, 192.168.1.0/24. I don't want to create a new vlan; I want the wireless network to be part of the existing vlan.
I can't figure out if I need to use a BVI interface. I found what looks like a good document, http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/85x87x/857swcg/eng/pt2/wireless.htm, but this doesn't apply to my situation and I cannot figure out how to get things working on one vlan.
Any useful information would be much appreciated
Gareth
Stephen Rodriguez
Yes you would need to use a BVI interface. move the address from the vlan to the BVI, on the DotRadio0 interface issue the command brdige-group 1, and issue the same command on the Fast Ethernet. Move the nat inside statements from the FE port to the BVI and give it a shot.
The config referenced in the doc, just shows how to do it with multiple vlans. if you only have one, just set the interface to the bridge group, no need to do subinterfaces.
Hope this helps.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
hans.goes
interface Dot11Radio0
no ip address
load-interval 30
ssid xxxxxxxxx
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
channel 2437
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 input-address-list 700
bridge-group 1 output-address-list 700
bridge-group 1 spanning-disabled
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
load-interval 30
bridge-group 1
!interface BVI1
ip address x
ipv6 address 2001:888:xxxxxxxx
ipv6 bridge 1 protocol ieee
ipv6 nd prefix 2001:888xxxxxxxx
bridge 1 route ip
enable
I can't get IPV6 working yet and have no clue yet how to do WPA security on the wireless.....
but BVI/VLAN1 is working.
to do WPA with a Pre Shared Key
Int Dot 0
encryption mode ciphers tkip
ssid xxxxxxxxx
authentication open
authentication wpa-psk
wpa key-management 0
as for IPv6, make sure the image you have supports it.
HTH,
Steve
