Wireless performance between different VLANs
tiago.molinos
Level 2
Level 2
I have a problem regarding throughput over wireless when the peers of the data transfer are in different VLAN (separate networks).
Topology:
I have a 3560 L3 switch configured with two VLANs, VLAN1 is the PC Wired network and VLAN2 is the PC Wireless network.
Connected to this switch I have a 1602i standalone access-point.
I have connected two PCs via Gigabit Ethernet ports to both VLANs (wireless is disabled).
I have one wireless client connected via 802.11an (disabled 802.11bgn to rule out interferences) using 40MHz channel width in the wireless network (VLAN2)
Device description:
PC1 - Connected via Gb ethernet to VLAN1;
PC2 - Connected via Gb ethernet to VLAN2;
PC3 - Connected via Gb ethernet to VLAN1;
WPC1 - Connected via 802.11n to VLAN2;
Here's the the tests I've made:
I've used both iperf and multiple paralel FTP sessions with similar results.
PC1 -> PC3
447 Mbits/sec
Note: no routing involved, no wireless involved
PC1 -> PC2
220 Mbits/sec
Note: inter-vlan routing involved, no wireless involved
PC2 -> WPC1
80 Mbits/sec
PC1 -> WPC1
9.8 Mbits/sec <== PROBLEM
As you can see I have nearly a 10x factor decrease in performace in the last test presented. I can't find why this happens!
I've already updated both the access-point and the switch to the latest version avaliable.
I've also used an old AP1100G and got the same result, around 9.8Mbits/sec when in different networks and around 17Mbit/sec when in the same network.
I've tested with diffent security settings in the wireless ssid, but I always get the same results... a huge performance degradation when connecting two devices in different VLANs.
Any suggestion? Thanks!
17 Replies 17
We’ve found the origin of the problem. It had to do with a badly configured gateway IP address in the DHCP Pool, for the network in VLAN1. We were experiencing asymmetric routing with one leg of the communication been routed through a Cisco 800 series. We've found that this issue was ongoing for the past few months.
Testing a new access-point took us to wrongly think this was a wireless issue.
Thank you for your help. You have been really useful!
Glad you finally identified the issue.
Yeah good job!!!!
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
