11-08-2005 02:34 PM - edited 07-04-2021 11:18 AM
Hello.
I have an 1100 series ap and an a/b/g/ pci card. Strength, quality and speed are all near perfect until my cordless phone is active. Then I lose signal quality and overall link quality, according to the aironet site survey tool.
What can I do to my AP or card to fix this?
Thanks!
11-08-2005 03:08 PM
I found a post that suggested better channels for the US. I was on 1 but, I switched it to 11 and it works great no when the phone is on :)
Thanks anyway :)
11-14-2005 10:10 AM
Buy a 5.8GHZ cordless phone...
03-06-2006 12:49 PM
If the cordless phone is a 900mhz one there is little you can do, the first armoinc o the 2,4 frecuency is very near. Try with other channels but microwaves and cordless phones conflict with 2,4ghz
