Wireless Point to Multipoint
I have a site presently using Ubiquiti GBE Plus as a point to point, but they are interested in adding an additional building. Which MR can one use for a Point to Multipoint solution? Looking at the MR86 or CW9163E
aleabrahao
Meraki Community All-Star
You know you won't be able to use Mesh between Ubiquity and Meraki right?
I would personally go with the MR86.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
5 Replies 5
aleabrahao
both MR86 and CW9163E could be used in a point-to-multipoint setup, but it would depend on the specific requirements of your network and the environment in which they will be deployed.
Can you give more information?
Presently the Ubiquiti AP's are connected to the blue building, the idea is to connect both building as shown.
aleabrahao
I'm replacing Ubiquiti for Meraki
