Wireless Problem
Xintruder
Community Member
I have just implemented my first 877w router.
I used the gui for the configurations (excluding the wireless part).
I then followed a cisco tutorial in setting up wireless (the one with the ssid and relating it to vpn1).
I did all the tutorial except for the bridging part which I assume I don't need.
However, when I do: #show .. associations
(where .. is the word that includes an 11 in it -can't remember it from the top of my head-)
I see my only SSID linked to VPN as 'DISABLED'. I tried lots of things including no shutdown in the ssid mode, shutdown vpn1 (thinking I can re enable it - but guess what I lost my telnet session, lol).
I googled for a bit, but I wasn't able to find a solution.
How can I fix this?
Thanks in advance
b.speltz
Level 8
Level 8
VPN is supported for wired modules and not for wireless serives.Refer URL
http://www.cisco.com/application/pdf/en/us/guest/products/ps5854/c1650/cdccont_0900aecd8016ef57.pdf
bporter78
Community Member
what you need to do is bridge vlan1 and your wireless into bridge-group 1
Then you setup BVI1 (bridge-group 1) with the IP address, access-lists etc that you want
Then apply your vpn crypto map to your dialer0 interface and there you have it.
Traffic from both your wi-fi and wired devices will go across your VPN
If you email me your config I can have a look at it and make the changes that you need and send it back to you
[email protected]
