Wireless Product Recommendation
aschweers
Community Member
Hello, I have a resort with several casitas, I'm looking to use Meraki mesh to connect the casita to the core network, however, I need to place an AP inside the casita to provide internet access. Can I hang an indoor AP off an outdoor Meraki AP? Or would I need a little switch to power both APs (indoor and outdoor) to make it functionable. Any caveats to doing something like this?
Thanks!
mloraditch
Meraki Community All-Star
In theory this should work:
https://documentation.meraki.com/MR/Wi-Fi_Basics_and_Best_Practices/Extending_the_LAN_with_a_Wireless_Mesh_Link
You would just need to use two injectors and then connect their data ports to each other instead of having a switch. I personally would want a switch so I can fully power cycle the AP and only need one power plug, but it may not be worth it depending on your needs.
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
mloraditch
BrandonD1
Just to touch on the above comments as well as your question on caveats, as a general wireless networking rule: each wireless hop in a mesh network reduces the throughput of the link in half due to the half-duplex nature of wireless.
As a result, wireless mesh networking may not be the most viable solution for environments that are required to support high-bandwidth or latency-intolerant applications. Meraki recommends limiting the amount of wireless hops to one (1) unless more are absolutely necessary to serve additional wireless clients.
That being said, if getting a direct cable to the AP is not an option this is most certainly the next best option :). A very good Mesh resource/best practice article can be found below:
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it.
