Wireless Profile issue
Sohail Muhammad
Level 2
Level 2
Hi all,
One of my client was using Autonomous Wireless setup in 2 of their offices, and user authentication was done through Certificate based authentication using AD. In one of their office, saying Office-1, they deployed WLC 5508 and all the autonomous APs were replaced with LWAPP APs. Controller is integrated with AD using Microsoft IAS and users are successfully authenticating.
Now, there is strange problem. Once the user creates a Wireless Profile at Office-1 and successfully connects to the Network, and then he/she moves to Office-2, he is not able to re-connect to the Network and he/she has to delete the existing profile, create the same profile again and then he/she is able to join the Network. Wireless Profile configuration is same for both the locations, except for the thing that Office-1 has Wireless LAN controller and Office-2 does not have WLC. This issue is being faced with only Windows 7 machines, and on Windows XP, it is working fine without deleting/creating new Wireless profile. Looking forward for valuable response.
Regards, Sohail
Scott Fella
It's probably how the WLAN is setup. Can you post the show run-config from the autonomous ap and the show WLAN from the WLC.
The ssid is using 802.1x, should either be using WPA/TKIP or WPA2/AES. This should not be used together or mixed up like if you have on the WLC WPA/AES or WPA2/TKIP.
-Scott
Hi Scott,
Currently I have Show run-config of the autonomous AP which is as follows:
version 12.4
no service pad
service password-encryption
hostname DIFC_NGN_1
enable secret 5 $1$lAVY$r6aQXsi6VmDXsbzDlw.tB.
aaa new-model
aaa group server radius rad_eap
server 172.30.1.236 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid NGN8021x
   authentication open eap eap_methods
   authentication network-eap eap_methods
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 143A411F0F07232725
username Admin privilege 15 password 7 002940120758020A0E
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep mandatory
ssid NGN8021x
fragment-threshold 2300
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid NGN8021x
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 172.30.200.6 255.255.240.0
no ip route-cache
ip default-gateway 172.30.200.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.30.1.236 auth-port 1645 acct-port 1646 key 7 013E551058080F0320
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
Based on above AP config, can you please advise what configuration I should do on WLC to make it work properly? In the meanwhile, I am trying to get the show wlan output from the customer.
Regards, Sohail
Hi Scott,
I have managed to get the show wlan output from the controller. Here it is..
(Cisco Controller) >show wlan 4
WLAN Identifier.................................. 4
Profile Name..................................... NGN8021x
Network Name (SSID).............................. NGN8021x
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 7
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... WLC-METLIFEACLICO-DIFC-01
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 172.30.1.236 1645
   Accounting.................................... 172.30.1.236 1646
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
--More-- or (q)uit
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
--More-- or (q)uit
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
--More-- or (q)uit
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
--More-- or (q)uit
MSAP Services.................................. Disabled
Regards, Sohail
