01-17-2014 05:44 AM - edited 07-04-2021 11:59 PM
Greetings, we have two 5508 WLC's in our HQ, all AP's connected in local mode and heavily use MS Lync over wireless.
We have 5 SSID's configured for various functions, one of which is the corporate SSID which users associate to by default, at present the QoS policy is set on all WLAN's to Silver.
Based on information from various sources and tech docs from Cisco i have thus far created the following AVC profile and applied it to the Corporate WLAN to identify Lync traffic and mark it accordingly
Set WMM on the WLAN to required.
And configured 802.1p settings on the Silver QoS profile
I have also configured the switch ports connected to the WLC's to trust COS (mls qos trust cos) all switch interconnects/uplinks to trust DSCP (mls qos trust dscp) and all access ports connected to lighweight AP's to trust dscp.
Now this is where i start to get confussed:
Any recomendations would be appreciated.
Solved! Go to Solution.
01-17-2014 08:01 AM
yeah, QoS is just weird all around.
It has to do with the WLAN QoS, 802.1p tag used, and what the client sends.
When you are set to Platinum the WLAN accepts up to EF as a tag
on the sired side, the 802.1p is going to match to 6
take a gander at:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/vowlan/41dg/vowlan_ch2.html#wp1046206
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
01-17-2014 07:01 AM
You do want to enable dot1p. The dot1p is for both WLC to AP packets and packets destined to the core
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807e9717.shtml
HTH,
Steve
01-17-2014 07:29 AM
Have thus far had the following results
One laptop connected to wireless, the other connected to wired LAN
Wireless Laptop - 10.45.57.134
Wired Laptop - 10.45.35.13
Also using default COS-DSCP maps on switches
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 8 16 24 32 40 48 56
Capture on wired PC with Silver QoS profile and AVC profile enabled
Source - Wireless
Destination - Wired
Traffic marked as CS2
Capture on wired PC with Platinum QoS profile and AVC profile enabled -
Source - Wireless
Destination - Wired
Traffic marked as CS5
Capture on wireless PC with Silver QoS profile and AVC profile enabled
Source - Wired
Destination - Wireless
Traffic marked as EF
Capture on wireless PC with Platinum QoS profile and AVC profile enabled
Source - Wired
If i remove the AVC profile all traffic is marked DSCP default in both directions however QoS settings havent been pushed out via GPO for our Lync deployment
01-17-2014 08:01 AM
take a gander at:
HTH,
Steve
01-17-2014 08:37 AM
Cheers Steve, have altered my cos-dscp map to mls qos map cos-dscp 0 8 16 24 32 46 48 56 and the wired PC is now seeing incomming traffic from the wireless client as EF rather than CS5.
Looking through mrncciew.wordpress.com to get a better understanding!
01-17-2014 07:11 PM
Hi Mark,
Yes, that's a great blog . Hey, that's me & if your queries not get answered through those post let me know
Rasika
