Wireless range
toyinsekoni
Level 3
Level 3
I manage both AP 1000 and 1200 series aironet. I want to believe that the smaller the range (coverage) the higher the speed. I can i control the coverage range of each access point. Is it possible to contain it, it is going way out of the range we want it to reach.
What are the pros and cons of using a single band (802.11g) AP?
Daniel
andrew.brazier
Level 8
Level 8
Best thing to do is reduce the transmit power on the radio, default is maximum.
