wireless repeater
Is it possible to configure Cisco Aironet 1131AG access point to act as a wireless repeater for traditional ADSL Wifi Routers?
after finishing the below config on the Cisco Aironet 1131AG access point it didn't work and i'm very tired:
AP# configure terminal
AP(config)# interface dot11radio 0
AP(config-if)# ssid Guest
AP(config-ssid)# infrastructure-ssid
AP(config-ssid)# exit
AP(config-if)# station-role repeater
AP(config-if)# dot11 extensions aironet
AP(config-if)# parent 1 09c1.1e34.e345  900
AP(config-if)# end
what i have to do to get my access point work ?????????????
Scott Fella
The question is, does your repeater associate with the AP or is the issues that your laptop doesn't associate to the SSID from the repeater.
-Scott
Scott Fella
-Scott
