Wireless RF Doubt
veggetvettyu
Community Member
have a question that might not be well-formed.
In wireless communication, the 2.4 GHz and 5 GHz frequencies are well-known. In the 2.4 GHz band, there are three non-overlapping channels: 1, 6, and 11, which are spaced 5 channels apart. In the 5 GHz band, there are channels 36, 40, 44, 48, 52, 56, and 60, allowing for 24 non-overlapping channels.
So my question is: why is there a 5-channel gap in the 2.4 GHz band and a 4-channel gap in the 5 GHz band? How are these gaps defined, and why isn't there a 4-channel gap in the 2.4 GHz band and a 5-channel gap in the 5 GHz band?
@veggetvettyu
 For 2.4Ghz, we have in mostly countries 13 channles. Considering a 22 MHZ channel, the non-overlaps ones must be 1, 6 and 11.
Any other way to distribute it, would cause waste of RF channels and or interference. The idea is to aviod co-channel interference as well as adjacent channel interference. If you use change 1 and 5, for example, there will be adjacent channel interference.
For 5.0Ghz it is a bit complex but we can assume the same rules.
Haydn Andrews
As per above, its because the centre channels, channel width means that they dont overlap with other channels. The frequencies are not just limited to WIFI as well
*****Help out other by using the rating system and marking answered questions as "Answered"*****
