Wireless roaming in different networks
cristiano.nunes
Frequent Visitor
Frequent Visitor
In Wireless networks if we have two different networks with the same SSID when we pass from one network to another network, the client will change the ip network automatically or we need to disconnect and connect again to request another ip?
I would like to know this information to Flexconnect and local.
Thank you.
Best Regards
Cristiano Nunes.
Moin Ilyas
Level 8
Level 8
Hello Cristiano,
You don't need to disconnect and connect again if you have Layer-3 Roaming enabled.
To configure Layer 3 Mobility, following requisites should be considered.
  • SSID and security policies should be same across MAs.
  • Client VLAN ID should be different for Layer 3 roaming.
  • Either one or both of the bridge domain ID and client VLAN ID should be different for Layer 3 Roaming.
Please find the attached topology for better understanding.
Moin Ilyas.
