Wireless Roaming with FlexConnect Local Switching when AP NAT-PAT is used
rick505d3
Based on this document on Service Provider Wifi "https://supportforums.cisco.com/document/120596/cisco-service-provider-wi-fi-important-key-features", I know that with FlexConnect Local switching we can hide the wireless clients behind AP NAT-PAT (will configure under WLAN). The feature requirement is to have central DHCP enabled (will configure under WLAN).
My question is with regards to wireless user roaming from AP1 to AP2 in the same FlexConnect group when the WLAN is configured with NAT-PAT. The two AP's obviously will have different management IP addresses and hence the NAT-PAT for the clients behind them will be different. Will inter-AP roaming (without re-auth or client tcp session termination) work in this case ?
Rick.
0 Replies 0
