With 802.1X authentication, mutual authentication is implemented between the client and a Remote Authentication Dial-In User Service (RADIUS) server connected to the access point. The credentials used for authentication, such as a logon password, are never transmitted without encryption over the wireless medium. Most 802.1X types support dynamic per-user, per-session Wired Equivalent Privacy (WEP) keys to remove the administrative burden and security issues surrounding static WEP keys.
With the Cisco Wireless Security Suite, an 802.1X-based enterprise-class security solution, customers may choose from a variety of 802.1X EAP authentication typesincluding LEAP, EAP-TLS, and PEAPto secure their wireless LANs (WLAN).
LEAPServer and client authentication via a user-supplied logon password. Supported on all current versions of Windows, Windows CE, Mac OS, Linux, and MS-DOS.
EAP-TLSServer and client authentication via digital certificates. Supported on Windows XP.
PEAPServer authentication via a digital certificate; client authentication via a user-supplied password or OTP. Supported on Windows XP
