wireless router
ohassairi
Level 9
Level 9
hi
some times one mpls link with one branch becomes down.
while waiting for the ISP to bring it up i would like to setup an emergency solution based on a router that will establish a site to site VPN with our fw in HQ.
however my internet connection in the branch is based on wifi (wifi router from ISP that uses 4G)
what cisco router model can fit these requirements?
thanks
thanks leo but i already have the wifi router that uses the 4g gsm network. i need a router that can connect to my isp router.
my isp router has no utp ports . it only accepts wifi connections.
so the cisco router will be like a wireless workgroup bridge.
normal pc with utp ---switch----cisco router ---- (wifi)my isp router(4g)-------gsm network---internet
